Poseidon X and Kickr alignment?
Any one here familiar with the Poseidon X? I just bought a kickr and the cassette and derailler are not lined up very well. Its a 9-gear rear cassette on the kickr. The bike is a 1xmore than 9.
Indoor biking Newb here so pretty lost. Do I need spacers? A different bike? Its not on the list of incompatible bikes and seems to fit the dropouts ok. Thanks!
You’ll definitely need to use a spacer behind the cassette - iirc the appropriate one should be supplied with the Kickr. Apart from that, I would assume that the rear dropout is a standard 12x142mm thru-axle setup, so you just need to make sure you have the right adapters on the Kickr.
