SRAM Force 1 Hydraulic bleed help
Hi all,
Not strictly a training question, although hard to train without a working bike!
I am trying to bleed my SRAM Force 1 brakes. I have the Epic Bleed SRAM kit and also a EZmtb kit. Neither of these kits seem to have the correct fitting for the calliper end bleed port.
Anyone have any idea what adaptor I might need?
Thanks
While I certainly am no expert these seem like “non bleeding edge port” style of brakes. Depending on the kit the correct fitting should be included. If I am not mistaken it should be the same fitting as the fitting at your brake lever itself. From what I can tell it should be included in the epic bleed kit.
