Trouble Download ELEMNT Maps
Is anyone else having trouble downloading maps and updates to their ELEMNT units? I have an original Bolt and am close to pulling my hair out trying to update some maps. It usually takes forever, then “FAILS”. I’ve talked with customer service twice and they have been no help, blaming it on my WiFi. I have no trouble downloading anything else. So why is it the WiFi’s fault now?
I’ve had this with my Bolt a few times. It seems to be almost random as to whether it’ll work or not.
I had a similar problem with a few maps and deleting and re downloading them solved the problem for me.
I’ve had similar problems. The ELEMNT seems to need a bunch of free memory to do downloads—so I’ve always had to delete first.
I’ve also had this problem.
I found that turning the Bolt off and then restarting and redownloading the map results in much better speed and a better chance of completion. I once had to do that twice when downloading a very large map.
Same here. Last Saturday suddenly the map ‘disappeared’ from my screen after about 50km during a 180km ride and only the chevrons remained. I tried to delete all maps, reboot and then download all maps to the Bolt v1 couple of times. No positive result.
Eventually I have given the Bolt a factory reset and after that downloaded the maps again. Went almost seamlessly. The ‘almost’ was the map initially represented distance in feet, but after another reboot the distance was represented in (kilo)meters. Even though the metric settings in the companion app was set to ‘metric’.
Bolt FW version WB15-14984.
Same here, it is not wifi obviusly since it is syncing my strava routes while I am downloading the map. How could you explain that Strava is able to sync maps but not The roam app?
@Antonio_Medina_Milti Log a ticket with support. Sometimes they push updates and something may have gone sideways with your install.
Downloading maps is super slow with my Bolt. What works though - and this is annoying and very boring - is to keep the companion app open and awake on your phone while it is downloading.
One thing I’ve found too (with my Roam) is that if I’m using ‘public’ wifi, say if I’m cycling abroad and trying to use the hotel’s guest wifi, that can be really unreliable. But weirdly, even though I can’t download maps through my own phone’s mobile data, if I hotspot my phone (and then my Roam) to another phone, the Roam recognised that as a wifi connection, and it works. Can be pig slow, but it gets there in the end.
I had to delete a continent to be able to have European countries that I was missing. Now I would like to add my favorite states in the USA and when I go back there the states are dark and when I click on them they don’t offer me downloads!! “we see written deletion requested and the weight of the card. Can anyone tell me how could I redownload USA? Thank You all of you
How to upload map on Elemnt Rival?
Amazing, two years of complaints and this isn’t fixed. I’m waiting on a Canada map update that’s taken 20+ minutes and then just quit. I now have no maps at all. Not my first time with this happening. Garbage. I’m buying a Garmin tomorrow.
@Mark_Wells That sounds like you may not have enough memory on the device. You may need to remove maps before adding others.
Try reaching out to support.
I have the same issue Canada Maps. Deleted all and trying to download Canada maps and takes forever to download. It says 1.1GB, pretty sure my WI-FI is fast enough to download this.
Hey Mark. I’m going crazy with the same problem: trying to download Canada maps. WiFi is strong. Lots of space. Just get stuck in QUEUED and nothing happens. Delete. Retry. Power off. Power on. Same problem.
Did you solve this? I’ve written Wahoo support.
So frustrating.
That wasn’t the issue. The Roam had plenty of room. I’ve moved on to Garmin for better maps. Unfortunately now I have to deal with the crappy 840 workout screen.
Changed nothing and one day it just worked. Kind of a typical wahoo tech experience. :roll_eyes:
After wasting literally hours trying to update maps, the solution which works is to hotspot your phone and have the Wahoo device connect to this.
It looks like Wahoo have a peculiar and very particular sensitivity to public wifi - including services in hotels which are password protected. I cant explain it, but after over 3 hours wasted on different wifi networks, my phone hotspot worked instantly for all maps.
Such shit tech. But hope this helps someone else
The Bolt needs a 2.4 GHz wifi.
I have just found that my home wifi runs a dual 2.4 GHz / 5 GHz system.
I set the guest wifi to run just 2.4 GHz, logged the Bolt onto the guest account and maps and firmware updates just breezed through.
