Update crash ANT
Just updated System this morning,it totally messed up all my hardware settings, ANT is not even functioning, was only able to make it work via Bluetooth. Same results on 2 of my laptops. Anyone has the same issue?
First, it would help if you could provide the type of system you are using and the OS installed.
Second, ANT+ usually is stable but depends on 1 above.
Thanks for replying jmckenzie, one is Windows 10 home edition another, newer model, Windows 11 Pro, and yes, ANT is/was stable till this morning, had no problem at all
Did you recently get an update to Windows? I don’t envision Wahoo tweaking the ANT+ code in any way as that is very old and stable compared code.
So after bizarre last two days, it is all working well today, have no idea what happened. Thanks for support, cheers, safe riding
