Wahoo Core2 Zwift Cog <> Wahoo Systm
Hi I am using Wahoo Systm with a Schwinn bike, but I am thinking of buying a Wahoo Core2 with Zwift cog.
How does it work - do you need to shift by yourself or does the system shift for you?
Will it work with the Systm Trainings or will I need to switch to Zwift for fully using the Core2?
Thanks mark
Hello and welcome to the forum.
There have been some other posts on this subject. You can start here, and there are links to other thread inside this thread.
The gist of the idea is that while the Zwift cog can be used in ERG mode in SYSTM, virtual shifting with the cog is only available in Zwift. So, doing your fitness tests in SYSTM to get your 4DP numbers is possible, but requires a bit of a hack by either dual-recording with Zwift and SYSTM, or changing between level/slope mode settings in SYSTM while riding.
