beleroy
November 23, 2024, 9:26pm
1
Hello,
I have bought a kickr core and I have a specialized venge, and I wonder which thtough axe should I use: the 130mm or the 135mm?
I do not want the chainstay and seatstay to brake if they are not well adjusted.
Do any specialized venge uses the kickr core?
thanks for your help
If your Venge has a thru axle it would most likely be 12x142. Maybe reach out support if you’re uncertain
jheb
November 24, 2024, 4:19am
3
Generally speaking:
130 - Quick Release Rim Brakes
135 - Quick Release Disc Brakes
142 - Thru-axle Disc Brakes (as noted above this is most likely what you have)
148 - Thru-axle Disc Brakes “Boost” (found on newer MTB)
It may be one of those strange setups. I don’t remember a Vf ge with Disc Brakes. If that were the case, it would be 135mm and that configuration is not supported by the current CORE. If it does have disc brakes, it should be 142mm.
