When I load routes on my Bolt V2 it often doesn’t show the indicators for intersections such as “sharp right in 250m” and then blinking when I need to turn. How come that sometimes happens while it works fine other times?
It depends on the route file you upload I think - only some (like .fit) come with route alerts, normal .gpx doesn’t
Ah, thanks - that makes sense.
Exactly that. And not many route planning tools give the turn by turn. For example RideWithGPS will do it, but only if you create the route yourself (unless you subscribe). I’ve re-created a few routes that friends/clubmates have sent to get the fit file with the directions (once you’ve exported it, you can send it to whoever and they will have the turns).
