Hi all. After updating firmware on my wahoo kickr core it now won’t connect properly says connected but no data. What would cause this
Usually it’s because you’re still connected to the Wahoo app that you used to do the firmware update. If that was on your phone, turn off that device’s Bluetooth and see if that helps
I had this same issue. Disconnect everything from your Bluetooth, then turn your Bluetooth off from your phone settings. Unpair all your sensors you have connected to wahoo and Zwift as well. Unplug your trainer and turn off your laptop and phone for 30 secs.
Turn everything back on, reconnect your sensors via wahoo app. Login to Zwift and connect everything and you should be good to go. This came from wahoo customer service. I have attached the instructions so it’s clear.
