Would you please consider to add an option that enforce “North Up” or “Disable Rotation” even while navigating a route ? Thanks in advance.
I can see why you (and others) might want something like this but it would drive me batty to have North up when heading in any direction other than North. I am directionally challenged as is and because of this, I have a data field that shows the direction I am heading
(p.s. also, since this is a request for a feature on the Bolt/Roam Companion App, and since Wahoo has yet to create a public forum for that, I’ve moved your topic to Equipment. SYSTM (wahoo X) software has no navigation features)
Thanks for moving my topic to the right place, Equipment.
I know some (most?) people prefer “Heads Up” like you, but I believe there are certain amount of people who prefer “North Up”. For me, the rotating map drives me batty even while navigating a route.
If you do googling with words like “heads up wahoo” then you’ll find various complaints that Elemnt ROAM/BOLT doesn’t have this feature, e.g., comments #340 in the review Wahoo ELEMNT ROAM Cycling GPS In-Depth Review | DC Rainmaker.
Oh I get it. We are all different. And, fwiw, I 100% agree with you that it should be configurable.
As a map person, I almost always prefer to have North always up. I can see why it is useful for many to have the map rotate and I do use it occasionally. But when driving I still prefer to have my GPS on my phone always show North up. When my wife uses Waze in the car it drives me batty to have the map constantly rotating and that disorients me.
Yep. I always use North Up on all nav devices (cycling and otherwise), incl paper maps. I’ve used Garmin Edge devices since 2010 and they’ve all had North Up options. Not having it would disqualify a device for my use.
Another vote for the North Up option.
And one more. Please!
Support the need for N up.
Same here, though on devices that do support it, north-up is not entirely my preference. There are actually three related topics here:
- Map orientation, obviously.
- Map centering: routing has the current position at the bottom of the screen. Gives you maximum preview when you’re following a route, but past a sharp turn in the route, or while getting around blocked roads, you don’t see what’s behind you, you don’t see the landmarks you saw a moment ago, you don’t see the general direction you were going or need to go. Even without north-up, I’d prefer to see myself in the center.
- Transition: right now (if you have the current limited north-up and the rerouting options enabled), when you (need to) deviate from a route, then the Bolt draws north-up while it’s rerouting, and switches back to course-up as soon as it found a new route. Disorienting at the moment you need assistance most. Although if think something like this might actually be the best of both worlds: when you deviate from a route, and the device has trouble figuring out where you’re going, and you have trouble figuring out what direction the device is showing, show us a stable north-up view, until we’re back on course.
My mindset when driving or cycling is that I want to know which direction I am heading just like when using a physical paper map. Its also easier to interpret/anticipate wind directions when riding. So please, please add a configurable option.
I agree with your request. Maps which keep on rotating when you’re navigating are a curse - it’s really hard, particularly in a complex city like London to keep track of where you actually are. I’d also like to be able to show a track on the screen without navigating it. I know it can be done by not having turn-by-turn directions and excluding the re-routing option but then, when you stop e.g. for meal or for social reasons, if you turn the device off it you have to re-set-up navigation wich is a hassle.
Yeah. Definitively want the option. The route chevrons are horrible enough. Rotating map is even worth
