Hello, as you can see in the photo, the saddle level is not balanced. How do I change this? By loosening the front screw, I was able to do so, but then I have to tighten it, and it goes back to the way it was. Thanks
Ok, figured it out, loosen the front screw till the level shows even, then tighten the rear screw and then tighten the front.
