Setting swims pool length
Hi just received the Wahoo ELEMNT watch and unsure how to set the pool length prior to a swim.
First swim was recorded in 25yards, after the swim I edited my swim to the 20m length pool and thought that would save the pool length for the next session. However when I swam it recorded it as a 50m length pool? I had to manually edit my swim afterwards.
How do I set it at 20m so it records my distance every time. Thank you.
Hello,
Change your workout to swimming mode, hold the menu (left bottom) button. In the menu you have a “Pool size” setting where you can switch between 25m - 50m - 25yd - 33 1/3m - 33 1/3yd - Custom
You can then choose the adequate length.
Life saver! Thank you
Regards
Clare
