Ticker HR Monitor
My Kickr bike is a week old, my Tickr hr monitor is even newer.
I can’t get them to communicate consistently. Every time I call the minions it connects, but today it never did while performing the 4DP test.
Any thoughts or suggestions would be appreciated.
What device are you running SYSTM on? What other devices or apps have you ever connected your HRM and bike to? You should make sure that those other connections are fully closed, usually by shutting down the app. Also, make sure neither device is connected to your phone directly (I.e. you shouldn’t see them in the list of Bluetooth devices on your phone).
I am using a MS Surface.
Update i have found that if the hrm is connected first, then everything in systm works as it should.
Thanks,
Dan
Glad you solved it.
