Same here
Losing gps signal, nothing help
Observe gps accurate and all the time losing gps or stay at 2
Same here
I’m having exactly the same problem. It was fine on the 14th August but today’s ride has been recorded as 2006. I can see it in the app too, but struggling to sync across to Strava.
Same problem on Aug 17th with my Boltv1.
And curious why Wahoo hasn’t made some sort of “we are aware of the issues”-post by now??
Hello,
I had the same problem yesterday.
Gps was lost & the date was from 2006.
Today the date is from 2025 but its says « GPS desactivated » & in the parameter I’m locked on indoorcycling mode.
I’m another one affected by this. Headed into the Surrey hills yesterday (17/08) and the GPS was inconsistent all ride. I purchased my Bolt V1 in September 2017 and have never had a problem with GPS before. Before I found this thread I reinstalled maps, unpaired from phone etc but I’m yet to head out on another ride to see if these changes worked
Same problem here with Bolt V1
Another having the sane issue. Do we know when it’ll be resolved?
Same problem, Bolt v1.
Time is OK, but GPS unusable as of Aug 17.
Dear Wahoo,
I am experiencing the same issue on my Roam Gen1 device since the recent update. When I display the GPS accuracy field, I see anywhere between 0 and 3 GPS locks, but with very very long periods of none. I have already tried a factory reset and deleted maps, but the problem remains.
Unfortunately, this caused me to lose recordings on two recent multi-day rides, which were bucket list rides for me. I was unable to log multiple sections, which was very upsetting (had to use my phone for navigation and was so worried about losing all the power on my phone and the power bank and not to mention the times stopping and starting to look at the phone).
Whether this issue can be resolved will determine my decision to upgrade and remain a loyal Wahoo customer. I have always been impressed with Wahoo’s support for older devices, and if a fix can be provided, I would be very happy to continue as a long-term customer. In that case, I plan to upgrade to the new Ace, while keeping my Gen1 as a backup.
Two attachments, one from Saturday ride missing so much of the 7h ride, and one from the South downs way missing a whole days section.
Ps. Also had a tyre blowout at 1:00 a.m. in a forest I didn’t know. Couldn’t get the device to GPS lock so I could work out how to walk out of the forest quickly. Had to guess the direction I was going for 45min.
thank you so much wahoo for that! ![]()
Please wahoo, could you work your magic once again and show your customers that you care.
Kind regards,
Owain
Same problem with me.
Yesterday o Ride with a Bolt 1 and the speed always Turn off and Turn on
I’m from Portugal
Wahoo Elemnt started playing up on ride yesterday, even after software update, ride not recoded. Very annoying, luckily two days before it recorded two new long rides, hope they sort this without the the ‘hardware no longer supported line’
I used my Elemnt Bolt V1 this morning and it seemed to work fine. Constant GPS connection and recorded my ride correctly. Unlike Sunday.
Did it take an update when you switched it on?
I don’t think it did. I have a ride home later so will check again.
Wahoo Roam V1 here, same issue. Resetting device to factory settings fixed the time issue for me - mostly. Its still jumpy showing time -1h directly after booting but showed correct time and date when I recorded a brief walk around the block. GPS is still largely disfunctional: the device is connecting GPS but drops off every ~200m. Looks like its going to be my old Garmin 510 for tomorrows gravel adventure.
yes, here same problem. GPS and date. Sunday and Monday. So I chanced logs for Strava but lost info on the Zwift.
Is there any update from Wahoo on whether & when this “bug” will be fixed? I had same issue on Sunday (17/8) with GPS lost and a map suggesting I’d had a short hop short from London UK where I’m based across the Atlantic. And this morning my ride which seemed to be recording ok disappeared altogether after approx 20 miles after gps was lost and is not in history with previous data lost & dates / times set back to 2006. Element Bolt bought in 2020. Do they self-destruct like a washing machine after x number of years so that you are forced to buy a new device?!
Here in Holland I had exactly the same problem (yesterday and today). It’s good to know it isn’t a problem of my Wahoo. So i’ll wait…
