Here the same problems, also in the Netherlands.
Glad that it is not only my device, I’ll hope it will be fixed!
Wahoo, I have the same problem with my Bolt. Losing GPS and freezing speed every few minutes. Some times auto pause for no reason. Just finished a 120k ride and it’s in the history dated 3rd Jan 2006. It will therefore not upload to Strava which is a major issue for my stats and targets. Please help soon.
Same issue for me, just started. Happy we know what the “issue” is, hopeful that a solution will be provided soon!
That is exactly the problem. The fix therefore is also easy. They only have to change the 1/jan/2006 offset to 17/aug/2025, and everything should be fine.
Same issue. Wahoo BOLT/ROAM V1 GPS Units Reset 20 Years Back, Becomes Unusable | DC Rainmaker has a temp fix for the data. Now let’s hope a fw update to resolve the offset will be there soon.
I have the same problem, wrong date(2006) , current time was 1 earlier than it actually was.
I thought something happened to my bike computer on Sunday with 2006 date. Then happened again today and kept on losing elevation and grade during the ride. I’m glad it’s not just my computer and hopefully they’ll release updated firmware fast.
I’ve had the same issue for three days with my element v1.
Issues connecting to gps, freezing map and ridiculous speeds. The system refuses to sync and changes the date stamp.
I’ve emailed wahoo without response
Day 1
After this I charged to 100% using wall socket.
Day 2
Loving the max speed! Drained to 0%, and did a soft reset.
Day 3
Following this I’ve done a factory reset, updated to most recent system and updated my maps.
Lets see what Day 4 brings (I’m doing a 12day long distance ride).
Sadly simple fixes like that usually still take days for enterprise sized organisations as the code needs to be reviewed, tested, released to a staging platform for QA, then release builds and testing of the release process before updating website with firmware change logs, informing customer service teams to be aware of the new release and to alert of issues etc. and finally pushing out the release for devices to pick up.
lots of cogs in the process … and unfortunately it takes some time. If they mange to release it tomorrow, 3rd/4th day then they’re doing well.
A lot of folk on their end are no doubt scrambling to get a fix out to us, and many meetings internally I’m sure to discover how it wasn’t picked up and allowed to happen give it’s a well known thing with GPS - and I’d rather that they get it right rather than rush a build out that could brick out devices.
I’m not so sure they’ll be a rush to fix this.
The v1 hardware is now very old, Wahoo wont be supporting it forever, everything has a lifecycle. They would much rather customers jump to v3 hardware. They will have balanced cost to fix this issue (even if it’s possible to fix the v1 chipset with a FW update) vs the profit of customers purchasing v3 and those who may look elsewhere. If the balance sheet say leave as is then that’s what they’ll do.
What I find frustrating is any official word from Wahoo. The only notice I’ve seen is via DCdrainmakers site. Says to me they aren’t in any rush to get this fixed anytime soon. Hopefully I’m wrong.
Either way I’ll be jumping to Garmin, there’s no excuse not to have foreseen this, it’s the GPS equivalent of the millennium bug and for a tech company to overlook this is inexcusable. It’s almost like they never planned for the v1 chipset to ever be compatible with the recent gps time changes.
Just want to make it clear that v2 is affected too, like mine. These units are not that old.
There has been official word from Wahoo on their official support page.
I’m glad they’re working on it, and I agree with @Spin_Diesel that these things take time to test before rolling out generally. Hopefully we see it in the next day or two.
Once they’re done, I would love to see a post-mortem on this. In thinking about it, my guess is that when the Bolt was first released in ~2015, they knew the next GPS epoch rollover was coming on April 7, 2019. So, for reasons (?) they decided that the Wahoo weeks would start on Jan 1, 2006 (a Sunday, 332 weeks into the GPS epoch) (also three years before Wahoo was founded…?), and coded Wahoo-week-num = (GPS-week-num - 332) mod 1024. Thus, everything was fine on April 7, 2019… but they forgot the Wahoo-week would roll over on Aug 17, 2025. Oops.
I’m still curious why the time goes off by 1 hour, and why they chose Jan 1, 2006 for the beginning of time, and why the device goes nuts when the date resets (shouldn’t it just think it’s 2006 and everything work? Maybe it also remembers the last real time from phone / wifi in some parts of the code, and they interact badly…).
Your time is exactly 1 hour off and it is because it is adjusting to January, not August and in January you are on GMT instead of British Summer Time. I have a Wahoo ELEMNT and it is doing the exact same thing. It hit a block due to it being exactly 1024 weeks after Jan 1 2006 and the 10 bit data field only stores, for weeks, binary equivalents of zero-1023. Thus at 1024 weeks, reached August 17 2025, it reset to zero and recorded January 1 2006. My August 18 ride was recorded as Jan 2 2006 and uploaded to Strava that way. It looked like it had not registered the ride because of that wrong date. However I found it, saved a fit file and used something online called fit file tools at this online link to fix it, then do a renewed upload to Strava. Manually correct the start time and date. Date is your actual riding date and start time is only 1 hour after it says your start time is. Your device recorded times correctly but since it thought it was January, did not adjust for what we call Daylight Saving Time, equivalent to your British Summer Time.
Normanh
Thanks for that but… where is the date stamp? I have three files and 5386 lines of code… all gobbley gook and when I search for anything resembling a date/time, nothing shows?
Normanh
Thanks for that, ignore my previous message, got to find the date changer, lol, looking into the data itself and not the options. Got there in the end.
Many thanks
StanLee
Edited after a test this morning. Similar issue with my bolt V1. The unit is not keeping up with navigating, loosing position, stalling and jumping erratically from a RideWithGPS route. I do not want to replace this head unit yet so I’m hoping that Wahoo can fix this soon as it’s useless at the moment. The date from the ride did reset to 2006, until corrected by WiFi.
Anyone know whether there were iterations of the v1 devices? I ask because I’ve been for two rides today and my Roam v1 has been absolutely fine on both. I bought it on clearance quite a while after the v2 had come out so would assume it has a later date of manufacture than many other v1s.
Does anyone else have a seemingly still functioning v1 computer?
Hello All,
I wanted to give some context into this, or as much as I can provide currently. We are actively working on addressing this current issue. For live up to date tracking on the progress you can go here https://support.wahoofitness.com/hc/en-us/articles/28876447336210-ELEMNT-BOLT-1-and-ROAM-1-GPS-data-and-ride-recording-issues-August-17-and-later
I know this sucks and is less than ideal, but I promise you the teams are working around the clock to identify why this happened and crafting a fix for it.
I know this doesn’t answer much, but I hope this can offer some vision into what is being done and some clarity on where the current status is at. I don’t know much beyond what is posted at that link.
Thank you for your understanding!
Cheers,
Mike G
Same issue here, I have the Bolt V2 and ride in Mexico. Hope that the next firmware update takes care of the issue.
