My buddy has a Bolt V1 and is 100% NOT affected. I was shocked when I told him about this and he said, “what?”. I wonder if it has to do w/ firmware versions?
Same here! Hope the issue will be resolved ASAP, because I really like to see good rides on my holiday…
I have had this same issue with my Wahoo Element Bolt while completing Eurovelo 15 from August 17. Have tried rebooting.
too much time has passed, it is highly unprofessional to continue to try and fix forward on this. the decision to back out the change and return to the last working version should have happened days ago. very amateur handling of a major IT incident.
Unfortunately, there’s never really been a working version. The problem has been in the firmware since the very beginning. In hindsight it probably should have been anticipated, but back in 2006/07 the person writing that part of the code likely didn’t expect these devices to still be around long enough for it to show up.
At this point, the only real fix would have to come from updating the source code. My guess is that nobody has touched this project in years, so before they can even patch it, they’ll need to revive all the tooling and testing to make sure nothing else breaks that people still depend on. The last thing anyone wants is for some of the devices to break or even get bricked by an untested update.
Just to be clear, I’m not defending Wahoo here — what happened is highly unprofessional and should have been fixed years ago. Either way, I really hope they either release a proper fix or help us replace these devices with new ones.
The downside of making a good product, it works longer than the software. At least they are working the problem and hopefully it doesn’t take a month
According to the firmware update page, there appears to have been 2 iterations of Roam V1 - https://support.wahoofitness.com/hc/en-us/articles/360005939120-ELEMNT-ROAM-v1-2019-Firmware-Release-Notes which can by identified by firmware prefix.
the other worrying part is in spite of numerous people reporting this is happening also on the Roam 2 (including myself) the update page only states this is affecting first generation devices.
Turned on the Bolt V1 this morning (21st Aug) and now it says “GPS is disabled” on the Route screen.
Running the latest firmware from May 2025.
If it’s happening with roam v2 then not all of the devices are affected. Friend of mine have no problems with roam 2 (everything works flawlessly) on August 20th.
I have a similar problem. My ELEMNT roam stopped standing my apps sometime after August/15. My last two rides on Aug/18 and Aug/20 have not been recorded and synced. The clock on the roam is also set to Jan/1/2006. I called customer support and so far no help.
Your rides are probably recorded - just scroll to the very bottom of your workouts on the Elemnt App and they will look like they happened on Jan 1-5 of 2006. ![]()
They will even sync with Strava if you manually do it - but they’ll still be 19 years ago…
I received the following email from Wahoo a few minutes ago:
Dear Robert,
We sincerely apologize for the recent inconvenience experienced with first-generation ELEMNT, BOLT, and ROAM bike computers.
Our team has identified the root cause of the issue, which is linked to the way these older devices track GPS time using a limited 10-bit system. We’ve been working around the clock on a firmware update to restore full functionality, allowing you to continue enjoying your rides with confidence.
Given the age of these devices and the upgrades we’ve made across our product platform since their release, we are thoroughly testing the update to ensure it performs smoothly. We expect to make it available to users soon.
We truly appreciate your patience and understanding. For the latest updates, please check this webpage, which we will continue to keep current.
Sincerely,
The Wahoo Team
It is not, unfortunately. My v1 Bolt is suffering of the same. Connected it to the app Sunday after a ride (recorded without GPS data), which apparently adjust date (and time, which was -1 h). But riding again yesterday showed that recorded workout presented date 05.01.2006, still no map (no GPS data) and the time again was -1 h.
For my device, adjusting the time (manually) is cosmetics, not fixing the root cause. To my 1st generation device, no update from Wahoo yet available yet per Thursday, August 21.
Same problem with my Bolt V1, of course. Since last Sunday, I’ve been getting very strange readings from my power meter and GPS issues on the route I’ve been riding.
On Strava, I got a very strange route and a red flag with the comment that part of the route was probably covered by a vehicle or that the GPS data was not accurate.
I thought my Bolt had had its day and was already thinking about replacing it. I’m glad I didn’t do that yet.
Ditto…intermittent display of speed, height, gradient…eventually the only item displayed was the time, and that was wrong, and it thought it was 2006.
After 6 days it’s really not that constructive to post on this thread simply to be the hundred and fifth person to say they’re having the same problem as everyone else. We get it.
News about a fix is what’s needed now.
I also fce the same problem: GPS lost and time in 2006!
Same problem - Thursday evening. Bolt v2 Ride Data logged as Jan 2006, not syncing. Hope the firmware update comes soon and works.
Son also lost data on a segment after he went for it - really frustrating
Thank you.
It means a great deal to me that my older device has not been turned into e-waste prematurely. The fact that Wahoo continues to support customers with older devices is an outstanding service.
I will no doubt be upgrading my device at some point in the foreseeable future, and this gives me confidence to remain a loyal Wahoo customer. I trust both the device and the service that Wahoo provides over time.
Kind regards,
Owain
