I think trainer difficulty affects your virtual speed, make it easier and you go slower.
Quote from the above article “Trainer difficulty has no impact on speed, the amount of effort you have to put out to generate that power will be the same if it was at set at 10% or 100%, although you will use different gears.” so this doesn’t really answer Malte’s question especially as the RGT session is a “competition”?
Seconded. Sneaky little bastard that. @#$% Time Triallers…
Literally the worst wording IMHO, but I sorta get why they want to say it that way. It’s power based to reach a certain speed… so changes your gearing, or change what the slope feels like to you (which effectively changes your speed for a given rpm, no?)
Is it possible to ride say the 1st. section now and the second section tomorrow and still have total effort counted against the May Challenge?
@Timothy1961 it may not be clear at first glance, but the RGT event has you ride two laps of the same loop, so you end up getting two times on section 1 and two times on section 2. I don’t know if they are looking at actual event completions, times in sections, or both, so I can’t answer your question precisely. That said, I don’t think you can teleport ahead in this event, so you’d end up riding section 1 again to get to section 2.
One lap is only 5 miles, so not a huge time commitment. The full two laps took me 43 minutes. You can certainly ride the event several times over the month if you wanted to.
EDIT - all that said this is the description on RGT “ride 2 laps of our favorite Italian Real Road in Wahoo RGT for your chance to win a signed EF men’s and women’s team jersey, as well as some Wahoo swag” and there was that pesky Terms and Conditions link above! I suppose you need to do both laps to have “completed” the event.
Thanks for taking the time to answer, I will try it some evening when I am feeling fresher, did Thin Air this pm; hope the old training is going well for you…thanks again regards Tim
Those segments in the ride - is there any way to find the ranking? Are they Strava segments or something? I wasn’t paying attention during the ride…
I join the question…
why, there is no determinable training benefit from doing a ride in RGT. To do a work out you need to pull in another source for the intervals, the terrain never matches the interval type and you don’t get any other skills or benefits from actually riding the bike.
Don’t even try and justify ‘racing’ as this is just a stupid way of poorly doing unstructure threshold efforts.
Different strokes for different folks… at least you are not forced to use RGT for the monthly badge. It’s not a structured workout environment per se, it’s a virtual cycling world (that does match the given gradient etc. when used that way) that can also be used to do structured workouts if you want.
While clearly it isn’t your cup of tea, there are many (and mostly entirely outside of these forums) that use RGT quite a lot.
Agreed. Somehow when I glanced at the profile I had it in my mind that it would only be a 10 minute effort … then reality set in after the warmup when I saw how much time still remained for this short workout.
“Short”. ![]()
@JamesJordan I have definitely found benefits from both RGT and also ProRides - using them as practice races when I can’t get outdoors.
To put it another way, the trainer % controls the flatness of the course, but not the watts to speed ratio.
Setting it to 80% will make a 10% incline on the map feel like an 8% incline to you. SYSTM will send a signal to your smart trainer to give you resistance corresponding to that 8% incline. If you put out 200 watts, you’ll get the same speed you would expect for a 200W effort on an 8% incline.
Theoretically, setting it to 0% would give you a perfectly flat ride, but I haven’t tried it. I did this route at 100% and gassed myself before the last big hill on the second lap. Rather than mess with the percentage, I opted to slap it into ERG mode lol.
Now that I think about it, for the purpose of equalizing segment standings, perhaps it gives you the speed output of 200 Watts on a 10% incline, even though you only felt an 8% incline’s worth of resistance.
Thought ERG mode in RGT only worked in workouts and not rides/magic rides/ events/ just rides??
Well, it definitely worked. After I do the other three May workouts, I will check to see if it actually counted haha
Please read manual first then write post
HERE
