I am looking at my Time in Zone in the History BETA section of Progress. It lists different Zone HR’s than my settings (higher). The * says it is based on current zone set as “Default”.
When I look at the Settings - Athlete profile, I see the numbers based on my latest FF performance. My max seems to be about 165 given recent training experience, which also matches closely w/ 220-age. They seem to be very close at the Top of Z3?
I am not sure why the 2 measurements would be different within SYSTM?
What do your zones in the Wahoo App say?
I bet this is just taking zones from there.
Yeah everything in History Beta is driven by the Wahoo App settings.
If you change your 4DP in one it changes in the other, but power profiles and HR profiles are set in WA, since these are used to determine the color data field zones on an ELEMNT.
This means you can change your 4DP but not your power profiles and your zones can be wrong. I asked them to add something where when you change your 4DP it prompts you to change your power profiles but I haven’t changed my 4DP recently to know if it does it.
