After a longer period biking, I did my FF test again this week.
What really was strange was my low heart rate during the 20 minute FTP.
I am sure I am not overtrained, (Perhaps undertrained? If that is possible)
How confident are you the data is correct?
This is just a stab in the dark, but did you happen to do the test on a TT/Tri bike?
No, MTB mounted on a Wahoo Kickr Core
Had a Wahoo Tickr X hr sensor, and also a Wahoo Rival bowht showd about the same values
Other question, how much different was the test he off of your ânormalâ max hr, and how did the test go otherwise? Did you feel like you were going hard and was the power there?
How did you feel during the 20 minute effort? What was the limiting factor, breathing, legs, fatigue?
Gotcha. Thanks! Definitely can see the HR is a lot lower
What I would look at is:
- was your power for the five min higher or lower than last time?
- was the power for the 20 min higher or lower than last time by how much?
If power was lower for both, and you were trying hard, then yeah, sounds like you were fatigued.
But if the power was equal or higher itâs maybe different story. IMHO if youâre actually riding at FTP, legs shoukd start complaining but your breathing and Hr shouldnât be getting away from you. If it does, likely means youâre above FTP (thatâs why doing a standard 20 minute test and taking .95 sucks so bad, bc itâs by definition above FTP)
Ok, weird. Reason I asked was that Iâve seen HR values get all wonky when people assume an aero position and the strap was too lose. Am I seeing it right that the HR shoots up during the recovery after the 20 min effort?
Could the watch have paired itself with the tickr?
Something is off with that data. The heart rate jumps back up after you had the break after the 20 min effort but before the 1 minute effort. Equally your HR never went up when you started the 20 min section. The 20 min section looks wrong. Does the battery need replacing in your HR monitor? Could there have been interference in that section? Did you turn an extra fan on for that part?
