I’m transitioning to outdoor workouts but my bike doesn’t have a power sensor. I do have a Wahoo Element Bolt and a heart rate monitor so I believe this to be my best option. I tried a Planned Workout today that was on my calendar and it came up on the Element as expected but there wasn’t a heart rate target when I was riding. The place where the number value should have been had a NA. Is this common with the outdoor workouts? What would be the best way to use the outdoor workouts in my case?
Have you linked your HRM to your bolt with the phone app??
There aren’t an HR data in the structured outdoor workouts. I asked this question when the feature first launched
RPE and following the workout instructions. e.g. sprint! is how I follow them
Thanks for the reply. Guess I’m just going to forget about the outdoor Structured workouts and leave it to indoor trading. Spent too much time staring at the Element anyways and not enjoying the scenery.
Any thoughts on trying with just heart rate. Any apps that will help? I’m using Strava but not much direction on this type of training. I guess it’s most important to have variations in your rate (intervals) to make more useful.
@SketchtyT Use RPE to train outdoors. You may need to practice indoors 1st using the RPE scale within SYSTM. Heart rate is a lagging indicator so it isn’t as helpful. Here are links to some related threads:
It’s now May 2025. I just encountered this exact issue and it’s EXTREMELY FRUSTRATING after you’ve paid for the subscription to ‘System X’ -and- bought the Wahoo devices … only to discover that OUTDOOR TRAINING by heart rate only is an ‘option’ – but doesn’t display the Target Heart Rate value. Contemplating doing a complete swap to a system that is more user friendly -and- a company that resolved issues quickly. Also discovered that entering a gym workout into the calendar isn’t a possibility either. Two strikes. One more … or, maybe just start the change over to Garmin now. Disappointed.
@Sean_Donahue If you are connected to Strava and upload a gym workout recorded on another device or if you record a gym workout using the Wahoo App it will appear on your SYSTM calendar and in history.
What Wahoo device do you have? There is a target heart rate field in the Wahoo App. Go to Workout Profiles, select profile, select workout pages, select workout data, select add data field, select planned workouts and there you can select the Target Heartrate field in bpm.
Note that heart rate lags so I generally use RPE as a target for outside workouts if I am not training with power. Even if I am training with power I like to focus on RPE - using it helps you calibrate your effort levels via constant practice.
