Recording Duathlon with Wahoo Rival and Element Bolt
Hi, I’m starting to race in duathlons, interested to know if similar to how there is a profile and touchless transition for triathlons, there is something similar for duathlons?, have searched on the internet about it but no one seems to mention how to record a duathlon with the wahoo devices, also have tried to use the triathlon profile but it doesn’t work as it expects a swimming leg at the beginning so it messes everything up. Any suggestions?
Just created a custom multisport profile for Duathlon with the Run > Bike > Run legs, will give a try and see how it goes, will update here later. Regards.
did this work for you?
Hi, well kind of, it recorded the 3 legs correctly but I needed to do the transitions manually in my Element Bolt, it was supposed to be a touchless transition but it didn’t happen, so I pushed the transition button on the Element Bolt twice when starting bike and then again twice at the end of the bike, that’s the only way I have found to record the 3 segments in a single multisport profile.
