Wahoo Elemnt Bolt V3 Syncing issues
Hi all,
I’ve had my Elemnt Bolt V3 for only a couple months now and it has been working fine up until today. I finished a ride and opened the wahoo app to sync. the app showed the syncing bar for about 3 minutes before saying it failed. I thought no problem I’ll try again, but the app refuses to sync today’s ride. The computer itself has it saved in the history, but the app is not displaying it or uploading to Strava. I’ve tried recording another activity and the app will sync and display that one, but not the one I need it too. I’ve tried restarting both my phone and the computer, deleting the app and redownloading it, and repairing them but nothing seems to be working.
Any help would be appreciated.
@MattL1 Are you away from your home WiFi by chance? I have had that happen once or twice and was not on my home network. Restarting the app and restarting the Bolt should make it pair but I have also had to unpair and repair as well on one occasion.
Reach out to support to see what they suggest:
https://support.wahoofitness.com/hc/en-us
I am on university WiFi. Repairing has not worked.
I’m having the same issue—re-pairing and restarting hasn’t worked either. Two rides today did sync but the third (only one outdoors) did not. It shows in Activity History in the device (Roam 3) but no amount of pressing sync is making it appear in the wahoo app and USB download doesn’t work anymore, sadly.
Same issue!
I have the same issue, they recently updated the software and clearly have broken it. Unfortunately recently they have a very poor track on doing this.
I have tried all the same things. Turning Wi-Fi on/off, turning the device off and on and killing the app, doing a new activity and syncing in which case get an error message that there’s a problem with the sync and to try again late. Does anyone from wahoo monitor this community to pick up issues like this? I have emailed support but they are quite slow to get back . Would seem staggering that they can break the sync process and not fix it quickly. It’s obviously been broken all this week as it worked for me last weekend but not this weekend.
I ended up figuring it out, but it might be a bit of a unique situation. When I rode, I recorded with both the elemnt and my apple watch. It turns out the wahoo app lumped both recordings into the same activity and had the apple watch recording displaying as default. In the activity, clicking the 3 dots and then changing the data file to the elemnt had it displaying the computer recording. I did have to reupload to strava.
There was an issue that a few internal users noticed over the weekend with syncing, it should be fixed now or the fix should be close to being pushed. Either way, we are on it!
I’m having the same issue. I just completed a very long activity — it shows up on my device (Wahoo ELEMNT Bolt 3) but I can’t get it to upload to the app.
I tried deleting the app and re-pairing the device, but it didn’t work. I also can’t get the device to connect to a computer.
Has anyone been able to solve this problem?
Is Wahoo going to fix synchronization issues? It’s over a year since Wahoo app release but basic features are still a lottery.
I have no synch issues, either from SYSTM, the Wahoo App nor from the Wahoo ELEMNT Bolt app.
If you’re having issues, you should open a support ticket with the Wahoo team.
I got the same issues. My Bold 3 isn’t syncing with the wahoo app and Strava.
I can’t input routes from Strava to wahoo. I already tried to disconnect the accounts and reconnect them (what took me almost one hour)
Still not working.
Edit: spelling
Cloud issues at the moment at Wahoo.
I got also a route deleted from last week…
I imported manually because it didn’t sync.. I hope to find it back :slight_smile:
Don’t worry, trust in minions! It seems all fixed :grinning_face_with_smiling_eyes:
Guys it’s crazy that device to iPhone sync depends on any cloud service. That should be decoupled.
How did you manage the manual sync? I tried finding those files via USB and OpenMTP, but only found some .fit files in export folders from 2025. Hopefully I won’t lose today’s ride. That would be the same as never going :smirking_face::joy:
I have synced Elmnt app with Dropbox so all files in Bolt are saved there. Luckily my issues were between Elemnt and Wahoo app. And on Wahoo you can load it.
So if it syncs on Elemnt I have the .fit file available on Dropbox…
Okay, thanks. Bit unfortunate for me then. Strava auto-sync was disabled since I reset it earlier when it was down (needed the route for my ride), and Dropbox wasn’t enabled either. Don’t think it’ll pick up past rides. :man_shrugging:
Hopefully it’ll come back once cloud services are online.
